A/C In Window Well - HVAC - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 04:09 PM   #1
A/C in window well
want to put a 5k ac in a basement room that has a window well about 3 feet deep. Will that work out OK
plschwartz is offline   Reply With Quote
Old 07-26-2012, 04:21 PM   #2
there may be some problems. first the compressor will run hotter due to the condenser (outside) coil being partially blocked by the window well. second you may create a water problem in your basement from the condensate. These size units are fairly cheap you may have to just try it to find out. You may be able to contact a manufacture of a window unit and ask them.
turnermech is offline   Reply With Quote
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
