A/C Window Unit Question Please - HVAC - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 08:44 PM   #1
A/C window unit question please
Bought me a big window units that says it cools 1000 square feet. Reason for this is that my compressor locked up per HVAC tech. Cant afford a new unit right now.
I have a few questions.
1. On my thermostat should i engage just the fan? Will it cool better with the window unit.
2. If no on the thermostat fan then should I close my vents?
3. Is it wise to run the ceiling fans with window unit or but some floor fans?
thank you for your time.
cichy1012 is offline   Reply With Quote
Old 07-16-2012, 08:54 PM   #2
Rewards Points: 266
A lot depends on the details of your duct system and layout of rooms. Just try it and see what happens. Likely that floor fans will move the air to adjacent rooms better depending on the layout. This way you might be able to choose what rooms to cool rather an all rooms.
ionized is offline   Reply With Quote
Old 07-16-2012, 09:09 PM   #3
keep the ceiling fans off also?
window unit ac not cooling properly in mobile home p5200 HVAC 9 07-05-2012 01:52 PM
basement window question kossuth Windows and Doors 0 06-27-2011 07:52 AM
New Window Question Underdog Windows and Doors 1 06-22-2011 10:23 PM
Pad under outside unit. Size question. firedogut HVAC 2 10-10-2009 04:36 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
