A.c. Will Not Turn On At All!!!!!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 02:56 PM   #1
a.c. will not turn on at all!!!!!!!!
I've owned my house for 1 year now. The a.c. has broken several times. It has a new compressor, new wires in the attic, just recently I had to replace the capicator. Then a few days ago I got a new Honeywell thermostat. It was running fine for two days and then it broke. The a.c. will not come on at all the outside unit or the fan inside. The outside unit is fine, the breakers are fine, I changed out the thermostat thinking that was the problem and still nothing. Not an a.c. professional does anyone have any ideas?
heathercz is offline   Reply With Quote
Old 07-04-2011, 03:15 PM   #2
JJboy's Avatar
What is your problem?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-04-2011, 03:48 PM   #3
Look and see if there's a float switch on a plugged condensate line.
Old 07-04-2011, 04:08 PM   #4
Check the contact switch
roofie is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Blower on furnace sometime did not turn on. max2k HVAC 1 06-15-2011 01:27 PM
Dumb Question: How to turn Gas Fireplace Off? mark2741 HVAC 1 12-14-2010 08:36 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 02:46 AM
