A/C Wall Unit Replacement/Sleeve - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 01:32 PM   #1
My current thru the wall A/C unit w/heater needs to be replaced. The existing model is an older GE unit (AJES12DCDM) and I am looking to replace with the newer GE model (AJEQ12DCD) or the Soleus KTW12H. The current sleeve is not a GE sleeve, but it fits the unit just fine. The only problem is that it does not have a rear grill (never had one when we purchased the house). I would like to avoid buying/installing a new sleeve and just purchase a rear grill since the unit is going to be expensive as is. However, I am having a very hard time finding out what make/model the current sleeve is.
Long story short....If I bought a rear grill that has the same dimensions, but not the same brand as the existing sleeve, will it work? I attached a picture of the unit/sleeve from the outside of the house.
Thanks.
A/C Wall Unit Replacement/Sleeve-img_0907-1-.jpg
collins79 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Fujitsu Halcyon AC wall unit dribbling water out of vents Big Murth HVAC 2 07-03-2010 02:50 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
