A/C Units - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2013, 10:17 AM   #1
A/C Units
I wanted to see if anyone out there would know if this compressor and air handler are compatible.
2TTA2036A3000AA Compressor
TWR037E13FB1 Air Handler
I want to purchase used and put them in a small 1500 sf rental house
Seabee2013 is offline   Reply With Quote
Old 08-10-2013, 10:30 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
By the 36 and 37 in the mod #s they appear to be 3 ton or 36,000 BTU which may be too big for that size of house unless it is poorly insulated in Florida or some extremely hot climate. Post the Brand names. they probably will fit and work together in the proper sized house. Do a load caLc to figure out the size. If they are too big they will freezeup the indoor coil.
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
Old 08-10-2013, 11:36 AM   #3
They are Trane units. They were taken out of a friends house when he added on, but were still working fine. The house they are going into is an old Florida home with the old windows and a converted carport turned into a room. It had a 3 ton Rheem system from 87 that just died.
Old 08-10-2013, 12:15 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
then they should work. may need some ductwork mods to make the air handler fit. now the trick is to get someone to install them.
Old 08-10-2013, 10:25 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 380
Poorly insulated house in Florida. Guess the Crystal Ball still works after all these yrs. Time to go buy some lottery tickets.
A/C Units-crystal-ball.jpg
Any theft prevention ideas for roof mounted AC units? Oliver126 HVAC 27 06-11-2013 08:42 AM
wall heating units ryanb4614 Plumbing 1 01-18-2013 07:54 AM
Placement of 2 outside AC units tarlan HVAC 2 06-26-2011 07:08 PM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 07:42 PM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 04:00 PM
