Old 08-10-2012, 12:10 AM   #1
A/C unit not cooling
What are the signs to let me know if my TXV isnt working.What should I look for concerning pressures or how can I check it?
BIG KERM is offline   Reply With Quote
Old 08-10-2012, 12:22 AM   #2
higher than normal head pressure. lower than normal suction pressure. higher than normal amp draw on compressor. higher than normal superheat. no cooling or not enough cooling.
turnermech is offline   Reply With Quote
Old 08-10-2012, 07:33 AM   #3
My previous post was for txv restricting too much. this could go bad the outher way and not restrict enought. In that case most posted above would be reversed ecept the superheat. lower head, higher suction and lower amps.
Old 08-10-2012, 07:42 AM   #4
Bchill
if your pressures wont stabilize and are moving up and down, this is called "hunting" and is a sign that the tx is bad
Acomfort is offline   Reply With Quote
window unit ac not cooling properly in mobile home p5200 HVAC 9 07-05-2012 01:52 PM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
Old carrier unit trouble hdbg62 HVAC 18 06-29-2011 09:57 PM
Heating and Cooling unit pauls HVAC 3 12-09-2008 09:49 AM
unit is trying to heat in cooling mode... gotdirtygrout HVAC 1 07-11-2008 11:00 PM
