Good Evening. First time user, so please bare with me. Today, for no apparent reason, one of two a/c units failed to cool (unit for the upstairs br's, ground floor unit fine). My wife noticed after a while that the circuit breaker had tripped. she searched on line for troubleshooting, and did a couple of the steps, and I replaced the circuit breaker with same type, thinking it had gone bad. When I hooked it back up, breaker stayed on for a few seconds, we heard what sounded like a growl, then the breaker tripped. tried one more time and same this happened. Trying to figure out what is wrong. Repair techs in this town charge arm and leg and will tell you lie to eek out extra money when not necessary. Any help will be greatly appreciated, even if for no other reason than I can challenge a tech as to what the problem is, versus what he may be trying to pull over on us. Thanks in advance. Additional info... home built in 2006, so still fairly new. no wire appear loose nor corroded in the box....
Good chance either the compressor or condenser fan motor is shorting out.
Don't reset the breaker again, until the problem is found and repaired. Continued resetting of the breaker will cause more harm to your system if its a short in the compressor.
Acid clean up can become very expensive. And continued resetting of the breaker, can cause more and more acid to form in the system.
You can do a little testing. Turn the breaker off first. Disconnect the wires going to the compressor,write down what went where as you pull each wire off. Try the system again. If the fan runs then it's the compressor. If the breaker trips then disconnet the fan leads and try again. Look for wires shorted to ground outside in the AC. Mice love to make them home for the winter and will chew on wire insulation,yellow and red must taste the best.
I worked with a guy that did that test. After he removed the wires from the compressor. The breaker didn't trip. So he condemned the compressor. I went with him to help get the compressor on the roof.
After we were up and had the recovery machine running. He told me how he determined the compressor was bad.
I went and got my meter up and checked the windings. No shorts to be found anywhere.
Started checking the rest of the system. Found the short in the condenser fan motor. it wasn't enough to trip the breaker unless the compressor was also running.
Just a FYI.
And we didn't change out the compressor. Instead, the company ended up with a 5 ton compressor instock.
Its not so much what the ohm reading is as a single number(should not have a reading to ground though).
But if the start to common and run to common add up to the start to run amount.
1 ohm isn't a bad reading. for a start to common reading.
While any of the above readings could be ok. They could also be high or low, depending on the temp of the windings at the time.
And weather its a recip or scroll compressor.
Compressor winding readings are taken to check if they are open, and then also added together to check for shorting and or shunting.
The start to run equaling the start to common and run to common are more important then the individual readings.
Life would be so much easier if everything was black and white.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
