A/C Unit Humming - HVAC - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 01:23 AM   #1
Rewards Points: 150
Exclamation
A/C unit humming
Been working on a wall with all the wiring and tubing for my central air unit above my head. Notice a humming seemingly coming right from the tubing and/or wiring. The hum starts followed shortly by the cool air blowing through the house as it should. The unit seems to work just fine, just want to make sure if this is a cause for concern as I am finishing this part of the basement and would rather get it taken care of now rather than after drywall goes up. Thanks.
Mijotter is offline   Reply With Quote
Old 05-10-2013, 05:09 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
It is the sound of the liquid refrigerant/freon running thru the lines. No problema.
Old 05-10-2013, 09:16 AM   #3
buzzing/gurgling
The buzzing is usually associated with the refrigerant leaving the metering device, and the gurgling is usually associated with the refrigerant going through the line to the metering device. and a small amount can be heard in the evaporator. this is normal and is a little annoying but there really isnt much you can do about it. maybe add a clamp with a rubber grommet and affix it to a floor joist or maybe a stud in the wall. that might help with both of these annoyances.
mchenry01 is offline   Reply With Quote
Old 05-10-2013, 11:42 AM   #4
Rewards Points: 150
Ok that's a relief. The humming continues until the unit shuts off...again, normal?
Old 05-10-2013, 11:47 AM   #5
Hvac Pro
yuri's Avatar
Yeah, as long as it runs it hums. You can add some insulation to the small copper line if it is driving you nuts or insulate the cavity the lines run thru also.
Old 05-11-2013, 01:35 AM   #6
Rewards Points: 150
Thanks a lot for the swift replies
Old 06-26-2013, 11:44 PM   #7
Rewards Points: 150
Is it ok for batt insulation to be stuffed in the ceiling joist cavity where the AC lines run? Are they ok to come in contact with insulation? Thanks.
Old 06-27-2013, 09:53 AM   #8
Rewards Points: 150
Anyone?
Old 06-27-2013, 10:00 AM   #9
Hvac Pro
yuri's Avatar
should B OK.
Tags
a/c , central air , duct , forced air , furnace
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Newly installed AC unit not working skye24F HVAC 10 09-29-2012 06:08 PM
Newbie attempting to replace an old condensing unit (please help) samboy HVAC 2 08-14-2012 04:21 PM
Can I upgrade the compressor in my RV roof AC unit? eoptrab HVAC 10 09-02-2010 04:43 PM
Evaporator unit is out under the house randyloy HVAC 1 08-29-2010 05:33 PM
