A/C Unit And Handler Run Fine, Just No Cold Air. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2011, 12:33 PM   #1
A/C unit and handler run fine, just no cold air.
Hi,
A/C unit and handler run fine, just no cold air. No funny noises or anything. Had a recharge and a capacitor replaced approx 2 years ago. Not sure which cap it was, or what they look like in my unit. Would also like to know what the rusty container that looks like a thick metal booze flask is. It has 6 wires coming out the top...2 dark yellow, 3 orangish, and 1 brown. Thanks.
Craig A is offline   Reply With Quote
Old 08-31-2011, 12:42 PM   #2
fabrk8r
fabrk8r's Avatar
A picture of the "thick metal booze flask" would help to identify what you are describing, but it sounds like a capacitor.
You say the AC runs fine, are you sure the compressor in the condensing unit (outside unit) is running?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-31-2011, 01:42 PM   #3
Thanks for replying. I think it is the cap since the 6 wires going into it look like the wires that go into other round caps that they show online. I am going to have it tested @ Grainger right now since I have to drop off my pool pump motor at a place right down the street from them.
Old 08-31-2011, 05:55 PM   #4
If you needed refrigerant 2 years ago and nobody fixed the leak then it's probably low again.
Full drip pan caused AC unit to cut off; now compressor/air handler will not work bizzow HVAC 1 08-14-2011 05:52 PM
Air Handler Works/Outside Unit Does Not g8tkeeper HVAC 7 08-03-2011 10:41 AM
Drain line plugged on air handler unit - need advice spta97 HVAC 19 07-26-2011 08:50 PM
New Condensing Unit to Match Existing Air Handler? sweaty HVAC 5 03-04-2009 01:37 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 10:33 PM
