A/C Unit Draining Lots Of Water - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 06:11 PM   #16
Household Handyman
Rewards Points: 1,408
You're worried about a 1/2 gallon a day discharge? I have an A/C unit which puts out a lot of water compared to yours. And- I run a de-humidifier at night which draws at least one gallon of water from the air within the house during an 8 hour period at night. Let's talk about muggy, , ,
Old 07-07-2011, 07:41 PM   #17
Rewards Points: 49
My unit rests on plywood on top of the joists. The pan looks to be supported by bricks to get it up off of the plywood. I should have taken a closer look, but it was getting rather hot...
Cultcab is offline   Reply With Quote
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Tankless water heater Navien cr-210 ? dotmatrix Plumbing 40 09-13-2010 10:29 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
