Old 07-09-2007, 02:08 PM   #1
A/C Unit for basement
In our basement, we are going to remodel it to be the master bedroom. It does not have heating or cooling as of yet. I have a piece of rental property that I am in the process of selling and the buyer is going to demolish it and has no need for anything in the building. I installed a new 3 ton A/C unit last August in the building that I am thinking about taking and using for the basement in our house. The basement is roughly 600-700 square feet. I know a 3 ton unit is an overkill for the basement, but could it be used or would that cause problems? Thanks.
mickmeister is offline   Reply With Quote
Old 07-10-2007, 01:01 PM   #2
I'm sure some of the pros will correct me if I'm wrong. The problem with going with a unit that large is "short cycling". While the basement will cool, it will feel "clammy" because the unit will not run long enough to get the moisture out of the air.
You may be able to get around this by adding a dehumidifier.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 09:51 PM
can I swap a (3) 60watt unit into a spot where I have a (1) 60watt unit? joeyboy Electrical 11 07-29-2007 08:25 PM
Question on 240v to ac(window unit) evosounds Electrical 2 07-21-2007 12:45 AM
Used Central Air Unit? shep28 HVAC 2 04-21-2007 08:59 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
