A/C Troubles....need Some Help Please. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2010, 03:00 PM   #1
A/C troubles....need some help please.
Hey all. Our home has dual A/C units. The unit that cools the main part of the house is not blowing cold today. I'm getting air out of the vents, the inlet is sucking air like normal but the outside condensor fan seems to be only running at half speed. We keep the A/C set at 80*. THe unit has been running solid for at least 2 hours and the temp in the house is now at 84*. We have Trane units outside and in the attic.
Any help would be appreciated.
Shane1 is offline   Reply With Quote
Old 10-12-2010, 03:23 PM   #2
HVAC / Plumbing
could be weak capicator or fan motor going bad
kenmac is offline   Reply With Quote
Old 10-12-2010, 03:46 PM   #3
fabrk8r
fabrk8r's Avatar
Do you have two condensing (outside) units? Are they both running differently than normal?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-12-2010, 07:08 PM   #4
Thanks for the replies!
I gave bad info on the fan. It is running normal its just the the unit is quieter due to the compressor not being on. From talking to some local guys that I found on Craigslist and reading a bunch of stuff here and on the internet it sounds like its a start capicator.
I do have two outside units and yes they are running differently.
Old 10-12-2010, 10:41 PM   #5
You mean run caps not start cap....
hvaclover is offline   Reply With Quote
Old 10-13-2010, 02:20 AM   #6
Yup I meant run cap, Thanks.
Can anybody give me a ballpark figure of what I should expect to pay for a new run cap installed?
Thanks again.
Old 10-13-2010, 04:26 AM   #7
Don't know your area but here in mi $230 to $260...might be way different where you are
Old 10-13-2010, 05:22 AM   #8
An old Tradesmen
Rewards Points: 6,516
Varies with how much coffee I have left at home.
Eaxh contractor makes his own price. And that is pretty much determined by the area.
Old 10-13-2010, 01:32 PM   #9
Thanks again for the replies. A tech came out today and replaced the defective run cap on the big unit (4ton) for $145.00. He mentioned that the run cap on the smaller unit will more than likely fail pretty soon, so he offered me the cap for the smaller unit for another $40.00. I figured since he was here it cant hurt anything. So I'm out $185.00 but my A/C works again.
propane furnace troubles grumpypapa HVAC 1 02-11-2009 01:32 PM
Snowblower Troubles dwhitters Landscaping & Lawn Care 1 02-03-2009 07:07 PM
Photocell Troubles Frogman1195 Electrical 12 02-03-2009 12:40 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 12:59 PM
HRV Troubles jweiner HVAC 8 01-02-2009 11:31 AM
