A/C Too Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2016, 02:29 AM   #1
Rewards Points: 32
A/C too cold
i am in a rented townhome and we have only 1 a/c heat controller in the living room for tne entire house. for most parts its ok except in small rooms. it gets too cold in the small rooms and i need some economical ideas to deal with it.
junkone is offline   Reply With Quote
Old 08-25-2016, 05:19 AM   #2
An old Tradesmen
Rewards Points: 8,154
Re: A/C too cold
Do the registers in those rooms have dampers in them you can choke down.
Old 08-25-2016, 09:46 AM   #3
Rewards Points: 32
Re: A/C too cold
nope, no dampers
Old 08-25-2016, 10:47 AM   #4
Rewards Points: 2,030
Re: A/C too cold
Originally Posted by junkone View Post
nope, no dampers
It may be time for DIY dampers.
Old 08-25-2016, 10:56 AM   #5
Rewards Points: 992
Re: A/C too cold
What happens if you switch the fan to be on all the time?
stick\shift is offline   Reply With Quote
Old 08-25-2016, 12:05 PM   #6
Rewards Points: 32
Re: A/C too cold
the fan is stuffy depending on the weather outside. its a matter of imbalance between small rooms and larger rooms. we need the a/c definitely for the larger rooms and not as much for the smaller rooms.
for eg.
1. the washroom is freezing when the a/c is on.
2. the home office where i spent most of my time is freezing(1 have 2 vents in this room which is half size of my bedroom). i need to wear my fluffy robe to keep warm when the weather outside is 90 degres.
I need a good balance.
Old 08-25-2016, 12:57 PM   #7
Rewards Points: 992
Re: A/C too cold
Right, your system isn't balanced so we're trying to help you do that. Dampers could have helped and sometimes running the fan all the time helps circulate the air better to even out the temperatures.
Old 08-25-2016, 01:11 PM   #8
Rewards Points: 8,196
Re: A/C too cold
running the fan all the time is wasteful and re-evaporates moisture off the coil when the unit shuts off.
Get registers with built in dampers and partially close them off in rooms that are too cold.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is online now   Reply With Quote
Hot water from cold pipes, plumbers are stumped seabeast Plumbing 75 03-31-2015 09:52 PM
Cold Air Return RichTibo HVAC 1 10-06-2013 09:16 AM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 05:50 PM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
