A/C Runs Too Long - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 07:38 PM   #1
Question
A/C runs too long
I have a question also.My A/C seems to be running to long now could it be the thermostat reeds replaced.It acts like its stuck.The A/C runs for 2 hrs straight.
Apostle is offline   Reply With Quote
Old 07-18-2010, 11:17 PM   #2
An old Tradesmen
Rewards Points: 6,932
Depends how hot it is outside, and what temp your trying to maintain inside. It should run 2 and often more hours.
The Following User Says Thank You to beenthere For This Useful Post:
Apostle (07-18-2010)
Old 07-18-2010, 11:39 PM   #3
Well it has been HOT here in AZ,and it seems to run like that from 1pm- 4 or 5pm the hottest part of the day.We keep it set on 79 or 80.Ang the differential on 1.5
Old 07-18-2010, 11:43 PM   #4
Electrician
Proby's Avatar
Wow, that's pretty hot, I keep my AC on 72, sometimes down to 70.
With these hots days lately (between 90 and 100 degrees) my AC has been running almost non stop during the day. I was told that is proper, your system should run almost non stop during the hottest days of the year.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
Old 07-18-2010, 11:43 PM   #5
An old Tradesmen
The hottest part of the day. And its only running for 2 hours. Thats not long.
During our heat waves, when we get 3 degrees above normal. Mine will run for 6 hours non stop. nothing wrong with it.
Old 07-19-2010, 12:01 AM   #6
Thank you all very much,I just thought it was running to long.
I wish everyone a blessed night and week to come.
Shalom.
Old 07-19-2010, 01:02 AM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I wish mine would run for only 2 hours. Think how much money you are saving over all of us where the AC runs for hours on end.
Old 07-19-2010, 08:42 AM   #8
Rewards Points: 150
Mine only runs for two hours, when I pull the breaker after two hours of use!
wetbar is offline   Reply With Quote
The Following User Says Thank You to wetbar For This Useful Post:
Apostle (07-19-2010)
Old 07-19-2010, 08:53 AM   #9
Yeah, mine seems to be running almost all day on the warmer days with going from my set point of 72 up to 76 sometimes. So I have been doing the little things to help it. I have taped all the joints in my duct and closed off all the registers to the basement (Since it is unfinished right now).. I have wrapped the duct in Reflectix bubble insulation, installed a new powered attic fan since my attic was unvented. And this has effectively brought down the temperature on the warmer days to 73/74ish. When a cold front comes through so I can have some time in the attic, I am going to go up there and spray foam the crap out of all attic penetrations and any everywhere near the return penetration. Then lastly will be a few more inches of insulation. Currently my attic insulation is from the 60's and has settled down to around a R20, and current standard in my area is R38.. so even if I get up to R30 i will be happy. Oh, and one large section of the firewall between the garage and house seems to be uninsulatied, so when i dry wall the garage, I will pull down that pegboard and vapor barrior and throw up some fiberglass.
These are things I have been looking at, that may spark some ideas in your area... but like others said.. I would only wish my AC unit ran for 2 straight hours then went back to normal cycle.
DAdams982 is offline   Reply With Quote
The Following User Says Thank You to DAdams982 For This Useful Post:
How long does it take for Aura to cure? slickracer Painting 8 01-03-2010 04:58 PM
Basement sump pumps, 1 runs more than other cjdock Building & Construction 3 11-02-2009 06:28 AM
Why long lasting bulbs go out of service quickly? art2670 Electrical 8 10-27-2009 08:10 AM
Rheem Criterion lights, but only runs for 30 seconds max... all4naught HVAC 2 12-26-2008 07:36 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
