A/C Runs Almost Constantly And Never Gets To Set Temp - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-14-2012, 08:57 AM   #16
ryanxo's Avatar
This may sound crazy but check your insulation. My insulation was only about 4 inches thick and I took almost every step I could to get my AC to push more and colder air. I ended up getting my insulation from R-9 to R-49 and now my AC barely runs at all and since the insulation covered my ducts in the attic my heat gain in my ducts is alot lower too. Air coming out of the vents used to hit 74 on hot days and now the highest it gets is about 66.
I also did continuous venting in the attic and that combined with the insulation has helped a ton.
My AC did have it's share of issues which all the troubleshooting helped such as leaky ducts that I taped up, redoing the trunk, getting the pressure exactly right, etc but adding more insulation would have been a hell of a lot easier and would have kept my electric bill from hitting $300 every month.
I am not an expert in anything. Any advice you take from me is strictly at your own risk!
ryanxo is offline   Reply With Quote
Old 08-14-2012, 05:37 PM   #17
The heat index was about 101 degrees yesterday. This morning I called out a service company and the technician checked the temp difference between the return and the air handler's output and it was only 12 degrees then he checked pressures and charged the system with 2 pounds, then he checked temps again and got a 17 degree difference. So I'll see how it works now. Thanks for all the help.
tyhorstman is offline   Reply With Quote
Old 08-14-2012, 08:21 PM   #18
Missouri Bound's Avatar
Don't worry about the heat index....HVAC is mechanical...it doesn't "feel" the heat index. I'll bet the 2# added and the new temperature difference will help immensely.
Do you want it your way or the right way?
Old 08-14-2012, 09:14 PM   #19
Just a FYI... AC's don't consume refrigerant so needing 2 pounds means you have a leak.
The Following User Says Thank You to Marty S. For This Useful Post:
Missouri Bound (08-14-2012)
Old 08-14-2012, 09:19 PM   #20
Rewards Points: 616
well said.... god got the 2 lbs... find the leak
carmon is offline   Reply With Quote
Old 08-14-2012, 11:07 PM   #21
I know, so far it's cooling a lot better but its a matter of time till we lose the refrigerant again, I'll have them search out the leak and repair it.
Old 08-14-2012, 11:38 PM   #22
That is correct. But "a matter of time" is relevant....could be two days...two weeks or two years. At any rate you need to consider your next step. 7 years is not too old for repair considerations.
