A/c Runs - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 05:00 PM   #1
Rewards Points: 81
a/c runs
I bought a house almost 2 years ago. My a/c is the original from 1996. I know...the time to change the unit is coming. Anyways, the a/c runs constantly. If I set the thermostat to 76, the coldest it will get is 78 (according to the thermostat) and never stops running. I live in Phoenix so it's hot as Hades but I honestly don't remember if we had this problem last year or not.
I looked on youtube and searched these forums and I think everything is clean and in good shape. Is it that I could need something as simple as a recharge? I'm sure it could be something much more extensive, but considering everything 'looks' good, this is what I'm guessing.
Does anyone know how to recharge a unit or if it's even legal for a homeowner to do it?
lendosky is offline   Reply With Quote
Old 07-11-2011, 05:08 PM   #2
JJboy's Avatar
Everything is legal until you get caught.
You need a pro to do the job. You don't want to spend money with gauges, refrigerant, digital temperature. Without saying getting education.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-11-2011, 05:21 PM   #3
Rewards Points: 81
lol. A rule I've always followed is "never break more than one law at a time"
I don't mind buying the tools if I can use them again because I'm a tool whore. The problem is that due to my unit using HCFC-22 which is an outdated refrigerant from what I've read. I guess I will have to call the pro in
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
Securing Cable Runs Over Block jkoll42 Electrical 2 03-15-2011 06:59 PM
runs and sanding oscarMadison Painting 1 02-24-2009 06:46 AM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 04:44 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 11:49 AM
