A/c Return Size - HVAC - DIY Chatroom Home Improvement Forum
Old 09-03-2009, 03:35 PM   #1
a/c return size
Two questions. I live in FL and my a/c return was located near the floor. Due to a renovation the drywall where the return was has been removed. Would it be better for the return to be closer to the ceiling (since I'm in an a/c dominated climate)?
For a 1600 sq ft home what is the smallest main return vent I could use? The workers already disposed of the old grill and I'm not sure what size to get to replace it. I think the old one was 20 X 16 but I'm not sure.
bmancanfly is offline   Reply With Quote
Old 09-03-2009, 06:39 PM   #2
If some could post the size of their unit and the size of the return, that would be helpful.
Old 09-03-2009, 08:16 PM   #3
HVAC
Return grill sizing I go by to be safe it 1sq/ft per ton of cooling. or 144 sq. inches. example 2 ton would be a 12x24
Hope this helps.
KAVF is offline   Reply With Quote
Return Register Size for 16" Flex hartkem HVAC 17 11-15-2008 12:13 PM
Help with return and supply size XHornet85 HVAC 9 09-17-2008 12:13 AM
Return Air Grille Size...? ssporty21228 HVAC 4 08-17-2008 11:00 PM
return duct size dave150 HVAC 4 02-20-2008 03:19 PM
What size should cold air return grille be? AllGoNoShow HVAC 1 02-27-2007 04:48 PM
