A/c Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 05:34 PM   #1
a/c question
Hi,
I know this make sound like a dumb question but where can you find the tonage amount of the condensing unit? Is it in right on the label?
markharmon is offline   Reply With Quote
Old 05-13-2013, 05:37 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
model number, usually. in multiples of 12 or half of twelve. examples would be a 2 ton system would have a 24 in the model number, a three ton would have a 36, a 3.5 ton (three and a half ton) would have a 42, the 36 plus half of 12 so 36 and 6 equaling 42.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-13-2013, 05:58 PM   #3
Can you tell me what the purpose of a draft hood is?
Old 05-13-2013, 09:38 PM   #4
if you're talking about a natural draft hood on a furnace it's pretty much so you don't die by way of carbon monoxide poisoning. heat rises, so naturally any exhaust fumes are going to want to lift out the vent, naturally.
Thanks.
Old 05-13-2013, 10:17 PM   #5
How does it prevent that?
Old 05-13-2013, 11:56 PM   #6
Experienced HVAC Tech
HVAC1000's Avatar
it pulls in additional air into the flue to keep an upward flow of flue gasses to they dont come out into your home and living space
HVAC1000 is offline   Reply With Quote
Old 05-14-2013, 07:41 AM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
Hi,
TRIVIA
And in a worst case scenario you can get the model # off the top of the compressor. Ie: AH2800675. the 28 means 28,000 BTUs. In our industry the compressors are actually rated in horsepower HP as well just like air compressors and other engines. The 28 compressor may be used in a 2 ton AC/24,000. Don't ask me why but they don't only/always build compressors with exact 24 capacity. Copeland, Tecumseh etc decided this a LONG time ago, we just buy what's available.
Old 05-14-2013, 07:47 AM   #8
Hvac Pro
yuri's Avatar
A draft hood technically the name is draft diverter diverts air into the front of it as the heat going up thru the furnace/heat exchanger creates a draft. this draft creates a venturi effect which sucks in air which is needed to allow draft up the chimney to remove all the fumes.
If you want a REALLY good book on gas burners etc buy this one from Chapters or wherever. It is the book they teach the gas course with here. Fundamentals of gas utilization. Take the ISBN # to the bookstore.
http://www.centennialcollegepress.com/fuel.html
The Following User Says Thank You to yuri For This Useful Post:
HVAC1000 (05-14-2013)
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
