Old 10-07-2012, 10:23 AM   #1
webweever's Avatar
A/C problem or are we setting it wrong?
We have a new construction 2 story house in coastal Ga. It has a single Goodman unit with 2 thermostats (1 upstairs, 1 downstairs). 2 zones with dampers.
We have it set on 74 upstairs and 75 or 74 downstairs. Its cooling the problem is it will only kick off for about a minute or 2 then kick right back on and it's only 74 degrees outside right now.
Do we have the thermostats set wrong or do you think there is a problem with the unit?
webweever is offline   Reply With Quote
Old 10-07-2012, 10:33 AM   #2
Professional
it will run if there is a call for cooling. it is likely that one zone is finishing it call and the other zone starts calling soon after. This is a problem that can happen with zoned systems.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-07-2012, 10:33 AM   #3
If its new get the builder to find out whats wrong... have the sent the hvac guys back
carmon is offline   Reply With Quote
Old 10-07-2012, 11:42 AM   #4
you are close to set point temperatures so, you might need your zone control and thermostats set up to allow for some differential between start and stop including zone over rides so unit doesn't short cycle
techpappy is offline   Reply With Quote
Furnace fan won't switch on--unpredictable intermittent problem arvonon HVAC 3 01-22-2012 05:46 PM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 06:20 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
