-   -   A/C Pop, Fizzle, Blowing Circuit (http://www.diychatroom.com/f17/c-pop-fizzle-blowing-circuit-122833/)
ErikU19 11-08-2011 07:53 PM
Hey Guys,
Came home to a hot house today. The blower unit is working fine. The compressor outside is not on, however. Checked the circuit breaker and the circuit is tripped. Reset it and turn the A/C on with the door open so I can hear the compressor kick on. I heard a pop, fizizle, and then the circuit tripped again. Walked out to the the compressor the unit is hissing and a electrical burning smell filled the air.
What do you think?
Capicitor? compressor? It is a Carrier unit, 9 years old. Never had problems with it before.
It's dark and raining so I couldnt see anything with my light. I'll have to check it tomorrow during the day.
yuri 11-08-2011 08:02 PM
BE VERY careful you DO NOT touch the outdoor unit with the power on. If the compressor has a short in it it will go to ground and if you touch it YOU become the ground and can get electrocuted. The compressor may be damaged by a power surge and the hissing is freon leaking out the fusible plug where the wires enter it. NOT a job for a DIYer if you don't have experience working on high voltage electrical equipment. The burning smell is burnt wires so you have a SERIOUS problem.
ErikU19 11-08-2011 08:29 PM
Thanks for the advice. I will leave the circuit off and wait for a professional.
On a different note what brand/seer unit should i replace this with if it is indeed bad?
This is a 4300sq ft 2 story house in Houston. Two zones. This is the lower zone/larger tonage unit.
Doc Holliday 11-08-2011 08:45 PM
You rang? :)
Seer rating for optimal SYSTEM performance would mean changing out the evaporator coil as well. They've gotten bigger to accomodate efficieny of the smaller compressors in the same size condensing units.
You can go 13 or 14 SEER condenser, if let's say your 9 year old one is a 9 or 10 SEER, and install a txv in the evaporator (if you currently have a fixed orifice) to get you by for another, well, until your evaporator coil springs a leak.
Now if you want to upgrade the refrigerant as well to R410-A then a new evaporator is strongly recommend but not mandaotory as on a lot of older evaporators they've made them compatible, but txv would be mandatory.
I'm not certain of the rules of offering our own services on this site but if I can not offer my own company then I can certainly steer you towards some good ones. Hopefully a moderator will chime in and let me know the rules.
Doc Holliday,
Houston, Texas
Marty S. 11-08-2011 08:55 PM
If it is the compressor the part should still be covered under the 10 year warranty. Labor,refrigerant and filer driers will not be though so it won't be cheap. Still way less then buying a whole new system though.
yuri 11-08-2011 09:27 PM
I believe the entry level units have 5 yr warranties on compressors, not to disappoint our poster. Depends if it is the builders grade or higher to know for sure. If it has burnt out then it needs a expensive flushing and cleanout procedure too.
Doc Holliday 11-08-2011 09:32 PM
OP, post the make, model and serial number of the condensing unit and I'll find out if it's under warranty for you, tomorrow.
ErikU19 11-08-2011 10:21 PM
Will Do. Thanks.
ErikU19 11-08-2011 10:23 PM
This just keeps getting better. Any chance it took out my plasma tv and refrigerator through some invisible line?:furious:
:jester:
beenthere 11-09-2011 04:13 AM
:jester:
Generally that would only happen if you have a bad electrical connection in your panel box at the main neutral connection. In which case, you should have moe appliances that are now burnt out.
ErikU19 11-09-2011 06:52 AM
BRAND: CARRIER
Serial #: 3702E06381
MODEL: 38BRC048350
:thumbup:
Doc Holliday 11-09-2011 07:41 AM
What coincidence, I'mm sitting out front of Carrier waiting for them to open at this very moment. Guy, I'll be able to tell the warranty for you and that'll be all I can do for you.
Doc Holliday 11-09-2011 08:20 AM
Not under warranty. Good luck.
ErikU19 11-09-2011 08:53 AM
Thanks Doc.
Do you do service in the Houston area? If so please send me a PM:thumbsup:
yuri 11-09-2011 02:21 PM
If you had a power surge check your homeowners ins. Not sure if it covers it. Also check with your neighbors to see if they got damaged. We had an incident where the elec utility damaged some wires in a back lane and damaged a whole row of houses. Had to fight for compensation but apparently they paid for the repairs.
