A/C Not Working - Thermostat Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 12:59 PM   #1
Question
A/C not working - thermostat problem?
Hello,
I currently live in a condo unit. I have no clue what the technical HVAC system is, but I'll describe it briefly:
You got your thermostat (digital, non-programmable). Directly next to the thermostat is the air intake (and filter), along with the removable panel to service some parts. The air (either warm or cold) is then vented out of 2 vents (1 vent in each room).
Here's the problem: the A/C hasn't been working. The thermostat reads a temperature of 80F, even though I've tried setting the temperature to everything from 70-76F (and even lower). There is even an A/C symbol displaying on the thermostat panel, which I assume means it thinks it's cooling. Could this mean the A/C unit itself is broken, or is it just the thermostat that needs replacing?
Note that I want to avoid anyone entering the condo unit if possible (maintenance person, etc.), as I have anxiety problems. I'm a DIYer by nature, so if it's a basic fix, I'm more than capable. I just need help in identifying the problem to begin with.
Please help.
pro_DIYer is offline   Reply With Quote
Old 10-18-2012, 01:09 PM   #2
JJboy's Avatar
need to check refrigerant with gauges. but becareful we are creepy
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-18-2012, 01:11 PM   #3
Refrigerant? That sounds like it's part of the A/C unit, right?
There isn't even any air coming out of the vents. It's not that the air isn't cold. There's literally no air being pushed through (the fans don't even turn on).
The fans DO work though. I can turn them on manually (just without any cold air being produced).
Old 10-18-2012, 01:45 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Is the outside condenser turning on when on call for cool or not? If when turning the system into cooling mode does the inside fan come on and blow air or not?
And I'm taking it this is a furr down unit, in the ceiling?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-18-2012, 01:46 PM   #5
JJboy's Avatar
you need a technician to check your unit. This problem is not DYI stuff.
Old 10-18-2012, 01:48 PM   #6
Not sure what kind of unit this is. I'm not well-versed in HVAC stuff.
Old 10-18-2012, 01:55 PM   #7
JJBoy may be right but we can try.
Where is the outside condensing unit? Where is the inside blower, in the ceiling?
Step by step tell us what it's doing when on call for cool. What's it doing while on call for fan only? What's it doing when on call for heating?
Without these questions answered we'll have a hard time helping. What I'm trying to do is figure out if it's electrical or not and where.
Thanks.
Old 10-18-2012, 01:56 PM   #8
JJboy's Avatar
if the outside condenser is running and the suppy vent is blowing not cold air you need someone to check the refrigerant pressure.
Old 10-18-2012, 01:59 PM   #9
JJboy's Avatar
Doc, i just wanna some our creepy friends to show up in his house. LOL
Old 10-18-2012, 02:12 PM   #10
Give me a bit, I'll post something soon if I can. Maybe even with pics.
Old 10-18-2012, 02:35 PM   #11
I don't think he meant only us but strangers in general and I'm the same way. I don't like strangers in my place either, I'm all suspicious.
Thanks.
Old 10-18-2012, 02:38 PM   #12
This is where Canada has us beat. They literally still sleep with their doors unlocked. Can't do that here in the US, we got extra dead bolts and burglar bars, security monitoring systems, dogs and guns and that's still not enough.
Thanks.
Thermostat Problem loftezy HVAC 4 03-21-2012 06:43 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Old Wall Thermostat to New Digital Thermostat Problem steiny HVAC 3 02-02-2011 05:07 AM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
