A/C Not Turning On At All. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 07:07 AM   #1
A/C not turning on at all.
This is my first experience with central air, so I'm clueless!
My landlord had to replace the outside fuse box, since someone lost the old fuse puller and we couldn't find another one to fit. So he gets everything set up, we turn on the breaker, and the switch on the furnace. Set the thermostat lower then the pleasant 90 house temp. But the a/c just clicks. The fans don't spin, and it makes no other noise other than the initial click.
Hopefully someone here can tell me it's an easy fix!
Thanks!
jlh4681 is offline   Reply With Quote
Old 06-25-2009, 01:50 PM   #2
Check the breaker box in the house to make sure the power to the unit is on.
SKIP4661 is offline   Reply With Quote
Old 06-25-2009, 03:07 PM   #3
I mentioned in my initial post that I flipped the breaker, and the power switch on the furnace as well. Other than that I have no idea what to even look at.
Old 06-25-2009, 07:21 PM   #4
as seen on tv
Rewards Points: 150
fuse in disconnect?
qbert is offline   Reply With Quote
Old 06-25-2009, 08:44 PM   #5
Originally Posted by qbert View Post
fuse in disconnect?
Or lack of
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 08:38 PM
turning off water Jack Hass Plumbing 1 02-03-2007 09:00 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-22-2006 11:35 PM
