A/c Not Coming On - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2008, 04:42 AM   #1
a/c not coming on
Dear sirs.
I woke up this morning to the a/c unit not blowing cold air. I looked outside to see if it was frozen & the unit was not running, but air was blowing inside. What could be the problem? one website said it could be connectors, wiring, condensor dirty. Please help, I live in south Texas.
v_thompson2001 is offline   Reply With Quote
Old 10-11-2008, 06:11 AM   #2
Electrical Contractor
kbsparky's Avatar
Check the breaker feeding the outside unit. It could be tripped. Check the disconnect box at the outside unit --- sometimes there are fuses in there.
Old 10-11-2008, 07:46 AM   #3
oops, did I do that!
Had any yardwork done lately? Maybe weedwhacked the low voltage wiring.
I take it the condensor has frozen up in the past? Could be a leak, out of gas.
Contactor coil burnt and not pulling in.
8 Ball is offline   Reply With Quote
Old 10-11-2008, 11:50 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Blown capacitor?
Kyle
Old 10-11-2008, 12:53 PM   #5
Originally Posted by SD515 View Post
Blown capacitor?
Gay electrons?
hvaclover is offline   Reply With Quote
Old 10-11-2008, 07:26 PM   #6
If you are comfortable with electricity see if there is power to the unit with a multimeter. Check both the low voltage at the high voltage. If you are not comfortable with electricity then call in a professional.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Sewage type smell coming from bathroom shower drain majorchamp Plumbing 29 06-25-2012 10:08 AM
screws coming loose Baffeled Building & Construction 4 08-13-2008 08:48 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Water Coming Out of Vent Line?? dost559 Plumbing 3 06-11-2008 08:50 AM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
