A/C Not Blowing Cold Air! - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 04:42 PM   #1
A/C Not blowing cold air!
Good evening!
My A/C is blowing out air, just not cold air. Fans inside and out are all working fine (this happens every summer). I turned off the electricity inside and out and opened the side panel. I found a burnt wire attaching to the capacitor but the capacitor does not seem damaged with the exception of rust. It is not swollen or leaking. Could the burnt wire be the problem? It seems as if the repairmen that come out every summer are always replacing something electrical.
Thanks!
A/C Not blowing cold air!-5.jpg
A/C Not blowing cold air!-3.jpg
A/C Not blowing cold air!-4.jpg
A/C Not blowing cold air!-get-attachment.aspx.jpg
Last edited by hearmeroar874; 07-27-2010 at 04:47 PM. Reason: Trying to add more pics
hearmeroar874 is offline   Reply With Quote
Old 07-27-2010, 05:01 PM   #2
An old Tradesmen
Rewards Points: 7,802
Looks like someone put in a single capacitor, instead of a dual.
Look at the wiring diagram. It should show if you need a dual or single capacitor. or has someone installed 2 capacitors.
Old 07-27-2010, 06:43 PM   #3
Sorry it took me a while to reply, but yes there are 2 capacitors. The other I believe is connected to the fan.
Old 07-27-2010, 08:25 PM   #4
An old Tradesmen
Those connectors came become loose and brittle from heat and age.
Cap may or may not be weak.
Old 07-27-2010, 08:27 PM   #5
I am going to start with replacing the burnt wire any further suggestions after this?
Old 07-27-2010, 08:28 PM   #6
Replace all those rusted connectors while you're in there. Poor or loose connections burn the wires like that.
Old 07-27-2010, 08:39 PM   #7
An old Tradesmen
What Marty said.
Old 07-27-2010, 08:44 PM   #8
Thanks! Do you think that this is why the AC is not blowing cool air? Or is it more than this?
Old 07-27-2010, 08:54 PM   #9
An old Tradesmen
Well. With that wire off. The outdoor unit can't run. So yes, its causing no cooling.
Old 07-28-2010, 01:22 PM   #10
Ok, let me rephrase my question. I disconnected the wire myself so I am aware that it won't work without it being reconnected. My question is this, due to the wire being burnt up the way it was, is that the possible reason for the non-cooling and should I go ahead replace the capacitor even though it appears to be in good shape?
Old 07-28-2010, 02:19 PM   #11
Why have you concluded that the capacitor is in good shape? Just because it hasn't exploded, bulged or leaked does not mean it's in good shape.
I would guess that wire got too hot because of high current flow, a very hot cap connector, excess resistance or combination of all 3. That could have come about because the capacitor's electolyte is drying out or it's developing internal shorts. Maybe even it's capacitance has changed due to age.
The short answer is yes. Fix the connector AND replace the cap.
hennyh is offline   Reply With Quote
Old 07-28-2010, 03:59 PM   #12
An old Tradesmen
All burnt wires should be replaced. Unless you tested the capacitor. You don't know that its in good shape. It may be what caused the wires/wire to burn.
Old 07-28-2010, 08:38 PM   #13
Thank you those were the answers I was looking for. Wires have been replaced but it did not make a difference therefore as you all suggested the cap will get replaced.
Old 07-29-2010, 03:48 PM   #14
Rewards Points: 338
was the compressor running? if the compressor was running and it was blowing warm air that would indicate a different problem.
NitroNate is offline   Reply With Quote
Old 07-29-2010, 05:17 PM   #15
Yes as far as I could tell the compressor is running
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 03:03 AM
HEIL/ICP gas/electric self-contained unit -- blowing cold air, won't shut off AboveTheBULL HVAC 3 06-28-2010 06:23 AM
Help! Furnace blowing cold air. Thanks. crosely HVAC 0 11-30-2009 10:17 AM
Blowing cold air but not enough jimmmy4 HVAC 5 06-11-2009 04:42 PM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 02:18 PM
