A/C Not Blowing Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 08:38 AM   #1
A/C not blowing cold air
Okay, first let me set up the situation. The A/C had been working fine, no problems, then night before last we had a storm and the electric went out. It would come on for a minute or two then go out again. It did this 3 times then went off completely for over 5 hours. That was during the night. Then when I came home from work yesterday it was 90 degrees in the house. The air was running but not cold. I turned it off for 3 hours then tried it again, no cold air. It doesn't sound like the compressor is kicking in but not sure, so I kept it off overnight in hopes this morining when I turned it on it would work. Nope. Don't know what else to do. Hate to call a company because I know its going to cost over a hundred and I really just don't have the extra cash right now but I cant stand another night of sleeping in 90 degree weather. Any help or advice you can give would be greatly appreciated!
thill914 is offline   Reply With Quote
Old 07-27-2011, 09:12 AM   #2
JJboy's Avatar
Let me know outside fan is running and inside blower is running.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-27-2011, 09:48 AM   #3
Outside fan is running. Not sure how to tell if the inside blower is running. Air is blowing out of the vents its just not cold air.
Old 07-27-2011, 10:08 AM   #4
JJboy's Avatar
Turn on AC in heat mode. Let me know it will blow hot air. I'm checking if the compressor is running. ONLY HEAT PUMP SYSTEM.
ok, do you have a multimeter?
Old 07-27-2011, 10:11 AM   #5
Experienced
Jackofall1's Avatar
[quote=JJboy;694659]Turn on AC in heat mode. Let me know it will blow hot air. I'm checking if the compressor is running.
JJ just a question, What indication is there in the OP's original post that suggests that this system is a heat pump?
Mark
Old 07-27-2011, 10:15 AM   #6
JJboy's Avatar
[quote=Jackofall1;694661]
Mark
You're right. I should have asked him.
Old 07-27-2011, 10:29 AM   #7
Experienced
Jackofall1's Avatar
Welcome thill914, to the best darn DIY'r site on the web.
Have you turned the AC on and gone outside to listen to the condensor unit? is the compressor acutually running? I know you said the condensor fan is running but is the compressor?
Mark
Old 07-27-2011, 10:40 AM   #8
Turned on the heat, air is not blowing hot, its the same temp of air that blows out when I turn it on cool. The unit is a Goodman CPLE24-1C if that helps.
Old 07-27-2011, 10:44 AM   #9
Don't know how to tell if the compressor is running.
Old 07-27-2011, 10:47 AM   #10
Experienced
Jackofall1's Avatar
Well now that we know its a heat pump, model number is always helpful.
The compressor will be an additional noise to the fan, kind of like a whining noise.
Mark
Old 07-27-2011, 10:49 AM   #11
Sounds like only the fan is running.
Old 07-27-2011, 10:51 AM   #12
Experienced
Jackofall1's Avatar
Take it away JJ, but it sounds to me like it could be the contactor.
Mark
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 04:03 AM
Stops blowing cold air after several hours awathen HVAC 4 06-07-2011 09:31 AM
Outside unit blowing cold air johna_d HVAC 1 04-10-2011 11:38 PM
Help! Furnace blowing cold air. Thanks. crosely HVAC 0 11-30-2009 11:17 AM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 03:18 PM
