-   -   a/c not blowing cold air (http://www.diychatroom.com/f17/c-not-blowing-cold-air-102834/)
verycold 04-26-2011 07:47 PM
a/c unit was working a day or two ago. now when you turn on the air the bottom fan comes on but the top fan does not.
The heat works fine and both fans come on.
i have noticed that the outside fan does not turn on when a/c kicks on.
all of these issues just started today
it is a goodman gmt045-3a unit
thanks for any help..
JJboy 04-26-2011 08:05 PM
Turn off A/C. You need to try to move the fan blade on the condenser ( outside unit ). If the blade moves with out resistance you need to check fan capacitor and the fan motor itself.
verycold 04-28-2011 09:50 AM
OK. fan blade moves easily. now how do i go about checking the capacitor and motor?
Marty S. 04-28-2011 04:28 PM
With a multimeter. Probably just a bad capacitor, they don't last long anymore.
JJboy 04-28-2011 05:14 PM
You need a multimeter that has option MFD.
First you need to do a visual inspection for any leakage or deformation.
Let say Capacitor: 10MFD +/-5% 370V
If you measure any values between 9.5 - 10.5MDF the capacitor is ok
verycold 04-29-2011 08:53 PM
alright. thanks so much for the direction. i think i may have figured out what the issue is. it appears inside the outdoor fan where the power connects is the issue. it looks like where the red cable hooks up has actually melted the wire a bit and the screw will no longer tighten. the black cable that hooks up to the same thing is not even screwed in. i found the screw on the ground below.
can someone tell me what this part is called and if it is specific to the fan or if this is a one part fits all?
i think this may be the second time this has happened. i seem to remember this happening a few years ago too. why would this keep going out?
thanks again in advance for your time
bob22 04-30-2011 07:06 AM
Post a picture; make sure electricity is turned off to the unit with loose wires sitting about.
Hubcap626 04-30-2011 07:17 AM
With you power off and check first with meter. Wires could melt from loose connections, undersized wire, or the motor could be going and it's drawin more amps and picking up more heat through the wire. Take some pictures if you can.
verycold 04-30-2011 09:57 AM
2 Attachment(s)
here are pictures of the part i was talking about
JJboy 04-30-2011 01:33 PM
It's time to change that contactor and redo the connections.
verycold 04-30-2011 03:37 PM
is this a generic part?
once i get the part is unplugging the fuse from where the power goes on the outside enough to kill power so i can work on it?
will somewhere like home depot or lowes have this part?
JJboy 04-30-2011 04:08 PM
http://americanhvacparts.com/contactors_search.htm
You should see a box on the wall close by the outdoor unit.
hvactech126 04-30-2011 04:31 PM
http://i1206.photobucket.com/albums/...eplacement.jpg
Hope this helps some when you get your new part. Wire colors are to depict which wire goes where, don't take them literally. Your wire colors are different.
yuri 04-30-2011 05:00 PM
Make sure you ARE NOT standing directly in front of the unit when you turn it on. If you accidentally wire it wrong and have a short you can get a huge welders flash and burn your eyes.
verycold 05-01-2011 01:02 PM
while i was trying to get the info off the side of the contactor i rubbed the label to get the dirt off and the entire label wiped off with it. is there a certain amp i should get for this unit. i know that the power on the side of the house for it is a 60 amp if that helps
