A/C Low Voltage Hook Up For A Secondary Electric Edison Meter - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2009, 10:33 AM   #1
A/C low voltage hook up for a secondary electric edison meter
I replaced a circuit board on a Bryant furnace and connected the low voltage wiring up from the t-stat and the condensing unit out side. but now I have a secondary electric meter just for the condensing unit that comes in down at the furnace, 4 wire and I can't quite remember how it went back in.
The unit out side was supplied by the utility company Mod: # 225121 and the catalog # is DCU 1193-1. which I can't find any information on.
I opened the out side box from Edison and found that the red and white wires coming inside the house from Edison are hooked to a transformer and the blue and green wires come from a circuit board with two little relays or at least I think they are relays.
Any help at all would be appriciated
Thank you in advance
Drew Foley
drewfoley is offline   Reply With Quote
Old 07-13-2009, 04:26 PM   #2
An old Tradesmen
Rewards Points: 6,086
Sounds like a load shed.
Does your electric company offer a lower rate if they can shut your A/C off when they need.
Old 07-13-2009, 04:50 PM   #3
Journeyman
Drew Foley
Here is the schematic from Edison. Normally if they they ran a 4 wire, Red,White,Green and Blue. Red and white is for the 24 power for the relay and blue and green are for the contacts. BUT without bieng there too see it who knows what they did. YOU NEED TO TRACE OUT THE WIRES. If you don't do it correct (poof the magic smoke comes out)
A/C low voltage hook up for a secondary electric edison meter-interruptable-service1.jpg
pipefitter636 is offline   Reply With Quote
Old 07-13-2009, 08:12 PM   #4
Sounds like you are in the Tri County area.
Isolate thermostat wires at furnace. Turn furnace off.
Identify the meter wiring. You should have red, green, blue, white.
Red goes to R on board. Blue goes to C on board. White goes to Y on board (there should already be a blue wire on the board from the thermostat).
You should have a green wire left over from the meter wiring. That will be used last.
You should have a two conductor wire that goes to the ac. They should be red and white.
Connect red wire to green wire with a wire nut. The remaining white wire goes to C on board,
Turn the power on to the furnace.
It will take meter up to twenty minutes to reset.
hvaclover is offline   Reply With Quote
Electric Meter SKIP4661 Electrical 12 06-21-2009 11:23 AM
help w/ voltage meter ugabulldog Electrical 7 04-30-2009 10:44 AM
90% Furnace, AC Drain, & Secondary drain pan. Hook all together? hartkem HVAC 25 11-18-2008 01:34 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
New W Meter Hook Up Question wannabuild Plumbing 2 02-01-2007 12:16 PM
