Old 07-29-2010, 04:10 PM   #1
Unhappy
A/C with little air flow
I just bought a 3600 sq ft condo penthouse with two roof central a/c units. The local HVAC guy put in freon and declared all is well. The flow from the registers is very weak even after he checked the returns which seemed fine. After several hours the Apt was cooler but not acceptable. What do I do? Where can I go to find someone to help?
Ira Romoff
IRA ROMOFF is offline   Reply With Quote
Old 07-29-2010, 05:31 PM   #2
It was a dark and stormy
Yoyizit's Avatar
Mr. R., there are 'bots that cruise the Web looking for any useful consumer info.
Old 07-29-2010, 09:00 PM   #3
An old Tradesmen
Ask your neighbors who they use. Hopefully not the same guy you had.
Or ask the condo association who they recommend.
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 06:05 AM
Flow switch use in Hydronic Heating System sarlaud HVAC 14 02-02-2010 08:03 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Will rebuilding a vintage facuet make it low flow now? twilightcall Plumbing 1 06-14-2008 01:24 PM
