A/C Leaking Through Leak Hole - HVAC - DIY Chatroom Home Improvement Forum
Old 06-11-2014, 11:23 PM   #1
A/C leaking through leak hole
My 4 yr old train AC is leaking through the weep hole on the bottom right of the unit. It is a small indent just to the left of the main out drain pipe. I have been running the AC for over a month and this just started happening in the last few days. Any suggestions on what this maybe and how to repair?
Thanks!
ckpalma87 is offline   Reply With Quote
Old 06-12-2014, 10:15 AM   #2
With a picture I am not 100% sure, but I believe that's your secondary drain hole. This indicates your primary drain is clogged.
clocert is offline   Reply With Quote
The Following User Says Thank You to clocert For This Useful Post:
plummen (06-12-2014)
Shower Leak Herk_Man Plumbing 10 04-14-2013 05:19 PM
Alum horizontal plane window is leaking. butwhydoitalk2u General DIY Discussions 1 11-01-2011 08:00 AM
well pressure tank leak wengang1 Plumbing 16 10-07-2010 09:59 AM
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
