A/c Issue Wont Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 03:03 PM   #1
A/c Issue Wont shut off
I have a A/c unit that it works fine no issues there but when it hits the thermostat temp it wont shut off it keeps on running. I even did a test. I put the thermo at 76 degrees and checked it later the temp was at 70 degress. I have already changed the thermostat and still same issue. Now what it also does is that when I have it on the off position by me manually turning the a/c off at the unit it self ImageShack® - Online Photo and Video Hosting . The fan turns on and it starts running. Today I opended a cover that its about 8x8 in size to look inside of it and see what was there. after doing that and putting the over back on my screw driver slip and hit the over and the fan turned on by its self. If you look at the pictures you will be able to see what I am talking about. ImageShack® - Online Photo and Video Hosting
I am trying to findout what is wrong with my a/c that it wont turn off when it hits the temp. Also the heat works fine no issues there.
Please assist on this if you have anymore questions please ask.
dsvm2004 is offline   Reply With Quote
Old 06-28-2013, 06:40 PM   #2
Supplier
You need to trace the control as well as power supply using a voltmeter and the electrical diagram to find out what exactly went wrong. If you are not comfortable with working with electricity it is better to get someone else to check it for you.
gsistore is offline   Reply With Quote
Old 06-28-2013, 06:56 PM   #3
I acutally got it fix. apperantly I have a 2 wire system. and the thermo has to stay on heat and just change the mode on the unit itself. then the thermo will turn it off and on. it works.now thanks for the help
New home roofing rippling/deflection issue daldelta Roofing/Siding 22 05-24-2013 05:24 PM
shut off valve behind toilet wont shut off Bunnypink Plumbing 5 04-20-2009 03:34 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Furnance burner won't stay on. 2007ken HVAC 11 03-03-2008 11:29 PM
