Old 05-30-2011, 07:25 PM   #1
A/C I smell my neighbor's smoke when I turn on my A/C
I live on an apartment building and my A/C unit is on the ceiling by the hallway. My neighbors smoke and I can smell it like if it was in my house, same thing when they cook. I am not sure if the firewall where the AC is cracked and the smell comes from there or if it is coming from their AC to my AC. Any help or ideas will help.
Thank you.
***I am the owner of this condo, I bought it without knowing about this issue. Would the home owners association be responsible for it?***
marite696 is offline   Reply With Quote
Old 05-30-2011, 10:22 PM   #2
An old Tradesmen
Call your landlord and let them know. You don't want to be messing around with it if you rent. Probably not sealed right between apartments.
Old 05-30-2011, 11:21 PM   #3
I agree with beenthere have the landlord check it.
Artco is offline   Reply With Quote
Old 05-31-2011, 06:41 AM   #4
Hvac Pro
If the landlord blows you off call the rentalsman or housing authority or fire dept as a last resort. Fire separation is a HUGE safety concern and they take it seriously.
Old 05-31-2011, 08:17 AM   #5
Thank you.
sound's like the key here is I bought it without knowing about this issue. Look's like you will have to fix it. I don't belive the home owners association is responsible . Sound's like the AC unit is located in the wrong place. In the hall way it will pick up what goes down the hall way. This mite be a big problum .You may have to relocate the AC ??? May not be able to do it ?? good luck I don't smoke and i know i would be upset
del schisler is offline   Reply With Quote
Old 05-31-2011, 09:51 AM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Any gaps, or even the smallest crack in a unit will cause orders to migrate. It is about Positive & negative airflow in how to keep this from happening. You may want to look at a filter that helps to filter those particulates out of the air when the unit is running, also seal any cracks under your front door with a door sweep, or door sock. Basically when your unit is running, it is pulling the air from the hall. Bad thing about apartments & condos, is most were designed before air quality was placed into the thought. Especially those buildings that are over fifty years or older.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Empire Wall Heater Smell? RickyBobby HVAC 10 12-22-2009 02:10 PM
Musty crawlspace smell coming into house tmpyankee HVAC 5 09-02-2009 06:34 PM
Cigarette Smoke digitap HVAC 9 05-26-2009 09:57 AM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
