A/C Hissing Sound - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 01:48 PM   #1
A/C hissing sound
I recently started hearing a hissing sound when the A/C is running. It continued to hiss after the A/C shuts off, for approximately thirty second before fading away. I went down into my basement were the sound is coming from. I can see a line with insulation around it, with another smaller (possibly copper) line running next to it. They appear to go outside to the A/C unit. On the smaller line there is an object that says something like "line heater/filter". I think the hissing may be coming from that device. Any idea what the problem is? Is this an easy fix? A/C seems to be working normal - maybe not quite as cool. Thanks for any help you can provide!
leted_82 is offline   Reply With Quote
Old 07-30-2007, 01:58 PM   #2
I do not think that is a problem, it is probably just the refrigerant blowing through the expansion tube/orifice/expansion valve etc... This would happen after the unit powers off until it equalizes. I suspect itis normal... now, if it is louder than usual I dont know...
Rick
maverick06 is offline   Reply With Quote
Old 07-30-2007, 02:13 PM   #3
Filter is hot
Thanks for the quick reply. I forgot to mention, I touched the thing that says it is a filter, and it is very hot. Do you know if this is normal or not? Thanks again.
Old 07-30-2007, 02:33 PM   #4
Rewards Points: 398
No it is not normal if you are talking about a liquid line filter drier. Make sure your outdoor fan motor is working and that the fins on your condenser are not plugged with dirt.
Malcolm is offline   Reply With Quote
Old 07-30-2007, 04:28 PM   #5
Outside Fan Motor!
Turns out it was the outside fan motor that had quit working. Thanks for all the help!!
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 07:36 AM
Water sound in Pipes Robb Plumbing 14 12-26-2006 10:48 PM
Strange Sound from Fridge Blaze25 Appliances 8 12-13-2006 06:39 PM
