-   -   A/c Help (http://www.diychatroom.com/f17/c-help-175341/)
david280 03-23-2013 07:11 PM
A/c Help
2 Attachment(s)
I had ac installed 2 weeks ago by what I thought was a pro,,and they did a bad install..
they covered (closed off) 8in x 12in of the supply opening on handler,,,and made a straight plenum not going into a distribution box,is this ok??
air handler sound like theirs a storm brewing inside,,and the air handler is on lowest setting 21/2 ton,,its a variable speed goodman,,,all the help would be greatly appreciated I spent good money and feel ripped off,,,
I would like to know what to tell them needs fixing,,( on top of the fact they probally oversized the unit 3.5 ton on 1400sf,, miami fl,,
thanks
sktn77a 03-23-2013 08:44 PM
Hard to see from your pictures and description but what exactly don't you like about the install?
david280 03-23-2013 09:38 PM
beenthere 03-24-2013 03:37 AM
Plenum only is fine. But the closing off of the air handlers outlet is not. You have a high static pressure now, and VS ECM motors don't like that.
yuri 03-24-2013 08:34 AM
Several problems:
1) The life of the motor is going to be shortened by the stress and it is a VERY expensive motor to replace
2) If it is a 3.5 ton unit with 2.5 tons of air going thru it then it will freeze up the indoor coil and damage the compressor
3) A oversized unit won't run long enough (short cycle) and won't dehumidify your house properly which is a major problem in your area
4) a UNit with excessive static pressure in the plenum sometimes won't drain the condensate properly from the indoor coil and it may overflow and you get ceiling damage
U should do a heat load calc, spend a few $$ and find out the proper size.
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
