A/C, Furnace/Thermostat Connection Breakdown. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2008, 12:20 PM   #1
Question
Can someone give me a down a dirty breakdown of how a A/C, furnace and thermostat connects? Ie. A/C fan and power connected to thermostat which turns on furnace fan.... ect.
I have a &%@#ed up installation and I want to have a general idea of what they did wrong. (bottom line, the furnace fan in my house controls the A/C, and the bath fan turns on the furnace fan which then turns on the A/C. )
mfleming is offline   Reply With Quote
Old 06-24-2008, 05:39 PM   #2
biggles's Avatar
R is 24V to any other it will run something(jump it to) with the stat off the subbase you have G,Y,W...R to G is FAN R to Y is CONDENSER outside and last R to W is heat.the selector at the stat FAN ON-AUTO in the ON position the fan runs all the time in the AUO it will cycle with the cooling setpoint.the fan can also run in the heating position but a normal cycle is that it is off till the furnace heats up and starts blowing warm air.
Old 06-24-2008, 05:51 PM   #3
Electrician
Are they using the furnace as makeup air when the bath fan is on? If so they probably just used "G" on the t-stat, the problem is that it will always back feed the AC unit, you just need a relay installed to isolate the "G" from backfeeding the AC unit, pretty simple actually.
chris75 is offline   Reply With Quote
Wall heater connection to breaker mw6263 Electrical 2 06-22-2008 10:47 AM
frozen gas line connection fisherziggy Plumbing 4 01-06-2008 02:37 PM
sub panel connection rtyui2 Electrical 6 11-28-2007 04:24 PM
Post to Piling connection george514 Building & Construction 4 06-07-2007 10:23 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 11:23 AM
