A/C Or Furnace (fan) Will Not Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2009, 05:20 PM   #1
A/C or Furnace (fan) will not come on
The thermostat is a fairly new digital one that runs on batteries and I have verified that the thermostat is working. I tied the wires on the back of it (to bypass the t-stat) and nothing still came on - fan or A/C unit. I can hear the T-stat click when I lower the temp on it - but that's it. There are no tripped breakers or fuses at the panel. I checked for loose or burnt wires and don't see any.
I am not sure how to verify that everything is getting power as it should. I have a Ducane Gas furnace (blower) that has a Honeywell circuit board on it. I have a multi-meter but am not sure what to test and where.
thanks Rob
robmaxfli is offline   Reply With Quote
Old 05-02-2009, 06:19 PM   #2
as seen on tv
Rewards Points: 150
test for incoming power at furnace.Test for control power 24v at control board r-c make sure the door switch is in on ducane i believe all you have to remove is middle door section. no power, test incoming on xmfr 120v and secondary 24v. If power is good leaving xmfr look for a small fuse on board.
qbert is offline   Reply With Quote
Old 05-02-2009, 10:00 PM   #3
Well, I looked at the circuit board and sure enough there was a 5A fuse that was blown. I swapped it out, the unit came on and then immediatly blew the fuse again.
Any suggestions?
thanks
Old 05-02-2009, 10:25 PM   #4
as seen on tv
Rewards Points: 150
good indication you have a low voltage short disconnect all tstat wires and replace fuse
Old 05-02-2009, 10:27 PM   #5
as seen on tv
Rewards Points: 150
[quote=qbert;268585]good indication you have a low voltage short disconnect all tstat wires and replace fuse or disconnect all tstat wires from furnace and tstat and ring out wiring with multimeter make sure wires are not touching
Old 05-02-2009, 10:30 PM   #6
as seen on tv
Rewards Points: 150
If continues you will need to trace the low voltage circuit further for shorts. You can follow the diagram on panel door.
Old 05-03-2009, 12:17 AM   #7
Qbert is right about wire digram
But I would look at the t-stat wires for bare spots. Although when you installed the new t-stat you probley let two wires touch and just need to space them out. Good luck.
texas115115 is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
