A/c - Furnace Fan Keeps Running - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2012, 08:11 AM   #1
a/c - furnace fan keeps running
Hi, My a/c - furnace has been running for quite awhile at a very low speed. My house is heated with in floor heat so fan is only used for a/c. What can the problem be?
yankfan7 is offline   Reply With Quote
Old 12-30-2012, 09:26 AM   #2
Rewards Points: 1,216
Check your thermostat is the fan switch in the auto or on position?
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-30-2012, 10:11 AM   #3
HVAC Tech/ Browns Fan
Limit stuck
Tator1076 is offline   Reply With Quote
Old 12-30-2012, 10:16 AM   #4
Bill Kearney
Rewards Points: 1,174
First be sure nobody hit the switch on the thermostat that turns the fan on (instead of just being on auto). Then make sure the thermostat isn't the problem. Some are mounted with a base plate that the thermostat clicks into. If that's how your's is setup you could pop it out to see if that changes the situation. Otherwise it's likely to be control board in the air handler. Further analysis isn't possible unless you post the make and model number of the equipment.
wkearney99 is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Pilot Ignitor Starts After Furnace Has Been Running Dr_Zoidberg57 HVAC 0 02-04-2012 06:45 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown Dr_Zoidberg57 HVAC 18 11-10-2010 09:52 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 07:01 PM
