A/c Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 07:42 AM   #1
a/c filter
what size ac filter do i use for a trane xr 80
ardensdad is offline   Reply With Quote
Old 06-30-2012, 08:31 AM   #2
HVAC Contractor
Rewards Points: 322
Depends on the size, location of the filter (internal/external) and many other things. The XR80 is a "line" of equipment, not a specific furnace.
The existing filter should have a size on it, assuming it's a standard throwaway filter. If not, then just measure the filter, head over to your favorite filter-buying location, and pick up a few.
If you don't have an existing filter, then you'll have to determine where (in the system) the filter is placed. Many systems have "filter grills", which are located directly in the living space. Others have filters in the bottom/end of the furnace, and still others have filters in racks mounted directly in the duct system.
scottmcd9999 is offline   Reply With Quote
Old 07-03-2012, 08:41 PM   #3
Rewards Points: 77
Also determine your efficiency, standard throwaway, merv8 ,merv11 or higher
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 05:49 PM
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 10:45 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
