A/C Fan Speed - HVAC - DIY Chatroom Home Improvement Forum
Old 04-20-2008, 05:44 PM   #1
A/C Fan Speed
I have a Carrier FK4BNF003 air conditioner which has a GE BF0S 1ROH 1/2 HP fan motor. With the CFM speed set on high, I am still not getting enough air flow. Assuming the vent system is okay (which I know is a big and often incorrect assumption), can I up-size the blower motor to get more CFM? (The unit claims 375 cfm/ton). (The unit is paired with a 38TRA A/C compressor unit.
knucklehead411 is offline   Reply With Quote
Old 04-20-2008, 07:41 PM   #2
Electrician
I'm not a AC guy, but how do you know your not getting enough CFM?
chris75 is offline   Reply With Quote
Old 04-21-2008, 10:02 AM   #3
Nothing scientific .. just low airflow from all vents. Three additional vents were added to the original installation, so the unit may now be undersized. I'm hoping I could increase the blower size/RPM without losing too much cooling. Thanks!
ceiling fan-wall transmitter for light and fan speed control stan 41943 Electrical 5 03-03-2008 04:27 PM
Furnace fan speed Kyle HVAC 12 01-16-2008 04:29 PM
electric fan speed control alynsach@cox.net Electrical 1 12-15-2007 06:24 PM
Two Speed Compressors rjordan392 HVAC 2 08-26-2007 01:32 AM
Slowing fan motor speed in air handler Manuel6 HVAC 7 04-17-2007 09:01 AM
