A/C Fan Motor Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-05-2012, 09:06 PM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Inside blower motor or outside condenser fan motor? Look for two sets of leads which may be wired to each other at the motor. If you have them than those leads can be switched to reverse polarity, change motor direction.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-06-2012, 06:59 AM   #17
Rewards Points: 1,216
Go back to your original post #1 and your question & answer you state when you spin the blade it runs. well did it run in the right direction back then before you changed the cap?????? Sounds like something is missing in your replies.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 09-06-2012, 09:13 AM   #18
Your are right, back then it was still running in reverse.
Would a bad motor cause it to run in reverse? I thought if a motor is bad, it would not run at all.
sean.of.to is offline   Reply With Quote
Old 09-06-2012, 11:44 AM   #19
My motor seems to be unidirectional. It does not have a wiring diagram.
Does it mean I cannot chnage the direction on this?
Could someone please give me some pointers on how to check the wiring?
Old 09-06-2012, 01:08 PM   #20
Replace motor and capacitor don't worry about messing with the wires.
Old 09-06-2012, 01:41 PM   #21
Is there a way to test the motor?
Old 09-06-2012, 01:51 PM   #22
You can give the motor 120 volts straight form the incoming furnace power. You'd have to unwire the 120 volts to the furnace and wire it directly to the motor, hot and neutral.
Turn the breaker off first.
Thanks.
Old 09-06-2012, 01:52 PM   #23
my fault, condenser fan motor.
240 volts so each leg is 120 to the motor, no neutral.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
sean.of.to (09-08-2012)
Old 09-06-2012, 04:53 PM   #24
An old Tradesmen
Rewards Points: 7,782
Originally Posted by sean.of.to View Post
I replaced my run cap and now the fan starts however itís running in reverse.
I think it has always ran in reverse...I am not 100% sure.
I have double checked and triple checked my wiring, it is exactly like the way I took it off.
Could the motor be bad?
The 2 wires from the fan motor that connect to the cap, just need to be reversed.
Old 09-06-2012, 07:13 PM   #25
Missouri Bound's Avatar
WHAT!!??
Do you want it your way or the right way?
Old 09-06-2012, 07:17 PM   #26
Originally Posted by Missouri Bound View Post
WHAT!!??
I didn't want to publicly state that as I'm unclear the facts but yes, it works but only in certain situations, under certain electrical circumstances.. I've actually done that on a furr down that was running backwards when I got there, just to try and it worked. BT will explain.
Thanks.
Old 09-06-2012, 07:19 PM   #27
WHAT!!??
Why are you shocked? Did you do this and it did not work?
Old 09-06-2012, 07:53 PM   #28
An old Tradesmen
WHAT!!??
LOL. Rotation is determined by the start windings(which are also the aux winding) on a PSC motor. On a 3 wire motor changing which wire is where, changes the sine that the start windings have. And will reverse the rotation of the motor.
On a 4 wire motor, changing the wire positions on the cap will have no effect.
The Following User Says Thank You to beenthere For This Useful Post:
Old 09-06-2012, 07:53 PM   #29
Reversing the leads on a capacitor of a fixed rotation motor will not change the direction.
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 09-06-2012, 07:59 PM   #30
An old Tradesmen
I change PSC motor rotation by capacitor lead change almost every month.
Download Fasco's Motor Facts for a good read on it.
