A/C Efficiency - HVAC - DIY Chatroom Home Improvement Forum
Old 07-22-2008, 06:33 PM   #1
A/C efficiency
Have a Carrier 2 ton A/C. Made in 1992. Trying to find the efficiency rating of this unit. Says high efficiency 2000 on it. No SEER rating. Model 38TR024300. Also 16 years old time to replace? No problems and it cools well.
Thanks in advance.
Frank
frankeu is offline   Reply With Quote
Old 07-22-2008, 11:09 PM   #2
oops, did I do that!
A 1992 Carrier Tech 2000, would have a SEER rating of between 8-10, if installed with the recomended equipment.
If it still works well, why replace it. If you feel you need to upgrade your equipment to take advantage of the higher efficiency equipment offered today, replace the entire package...furnace and air.
8 Ball is offline   Reply With Quote
Old 07-23-2008, 05:46 AM   #3
I am going to replace both. Furnace was built in 1982. Natural gas trying to find efficiency for that also. Probably would get a better deal to do both at once. Thanks for responding!
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
High Efficiency furnaces? jetchaser HVAC 3 06-19-2008 08:33 AM
high efficiency gas furnace hammer6315 General DIY Discussions 2 06-18-2008 11:25 PM
New High Efficiency Gas Furnace & Hot Water Heater frank08226 HVAC 2 04-17-2008 01:06 PM
NEED HELP - Energy Efficiency - Insulation/Windows and Doors bcrwfan General DIY Discussions 2 02-12-2007 01:46 PM
