A/c Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 01:26 PM   #1
a/c ducts
I think my a/c ducts in my basement have come loose. The unit is running as normal but there is NO air coming out of the vents. I went down to the basement and some of the ducts appear to be drooping but everything looks connected. Also, it is nice and cold in the basement.
Jillk is offline   Reply With Quote
Old 08-18-2009, 02:52 PM   #2
30 year tech
hvac122's Avatar
No air out of any of the vents or just in the basement?
hvac122 is offline   Reply With Quote
Old 08-18-2009, 04:04 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Did you have good air flow out of them before or just notice a lack of flow?
What's up HVAC122
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-18-2009, 05:08 PM   #4
I had excellent air flow until this morning....now I have a little in the back of the house but less in the front portion. I also found that one of my cats has found access to the basement & I think he was walking on top of the ducts in the basement. They appear to all be connected, but some areas look "droopy". Thanks!
Old 08-18-2009, 05:43 PM   #5
Rewards Points: 560
Start at the filter and see if it is clean, Then check the return air for no restriction.
You have done a cat head count?
Old 08-18-2009, 06:05 PM   #6
Thanks! All cats are accounted for....I fixed the panel back so they can't get down there. I changed the (filthy) filter and that seems to have resolved the issue. I can't believe so much dirt can accumulate like that (although I do have three cats AND three dogs)! Thankfully it wasn't as hot today as normal (Oklahoma) and it did rain a lot last night. Once again, thank you for your help.
Old 08-18-2009, 06:08 PM   #7
Rewards Points: 560
With that many animals inside or around you might check your filter every or every other month.
Glad to help
Old 08-18-2009, 06:13 PM   #8
bbbbbbb
hvaclover is offline   Reply With Quote
Old 08-18-2009, 06:35 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
You may want to get a professional duct cleaning company to clean the ducts. Better for your health and prevents the filter plugging as often. Don't call low overhead Lou as they don't spend the time and use a truck with a big enough vacuum. Pay more and get a proper job done by a reputable outfit or it is a waste of time/$$.
Old 08-18-2009, 06:52 PM   #10
30 year tech
hvac122's Avatar
What's up HVAC122
Not much this way. How bout you?
Noisy Ducts jasoncw HVAC 1 10-28-2008 11:51 PM
hard metal vs. flexible ducts katea HVAC 4 05-18-2008 08:23 AM
How far should insulation be from heating ducts... AllGoNoShow Remodeling 4 11-09-2006 05:47 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 04:26 PM
