Old 09-05-2012, 01:11 PM   #1
A/C ducts
3 of my rooms are not getting cool, but the rest of the house is really cool. I have looked at the ductwork in the attic and can't really tell if it is disconnected somewhere or not. There are parts of the duct work that is covered in insulaton, could that be part of the problem? Also, I noticed that there is a piece of duct that is open and pointed towards the turbin, is that supposed to be like that or does it need to be connected somewhere?
hughes458 is offline   Reply With Quote
Old 09-05-2012, 01:16 PM   #2
I'm Your Huckleberry
A/C ducts
Probably was left open when someone was working up there and wanted some cool air. It should be connected to something, either a splitter box (one big duct feeds a box that then has smaller ducts running from it to the rooms) or directly to a register.
Do you know if you have dampers? And btw, ducts should never be laying on the attic floor but should be strapped up. That's a part of your problem right there. Also check to make sure all ducts have no kinks in their runs.
If you do not have dampers on the ducts to control air flow do you have the aforementioned splitter boxes or "Y" configurations up there where again, a Y would consist of one bigger duct breaking off into two smaller ducts at a Y connection? It is always best to have dedicated runs and not split or Y'ed runs, especially without dampers.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-05-2012, 01:23 PM   #3
A/C ducts
The duct in the turbine is it connected to the return.
. Maybe fresh air?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Re-Route Ducts into Addition? CroMagnon HVAC 3 07-07-2012 09:15 PM
Transite HVAC ducts Jordy HVAC 1 06-18-2012 05:25 AM
Transfer ducts rock!!! bobinphx HVAC 18 01-29-2012 06:15 PM
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
