A/c Duct Holed - HVAC - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 08:28 PM   #1
Rewards Points: 119
A/c duct holed
Hi all
Quick question, while I was running speaker wire, I drilled through an A/C return duct. I pulled the wires through.
Any real down side to this.
we were trying to hide the wire behind the speaker, I don't have many options unless I must do something to correct.
Thanks in advance.
RALPH
RH913RH is offline   Reply With Quote
Old 08-21-2012, 09:03 PM   #2
Rewards Points: 13,270
I'm sure we could have came up with some better option that doing it that way, but's done now.
Only a few minor issues, now the holes need to be sealed around the wire, slim chance the wire flopping around in the duct may rattle when the blowers running, the bigest one though is over time the wire may chafe without a rubber gromit for the wire to go through.
Old 08-21-2012, 09:07 PM   #3
Missouri Bound's Avatar
Hopefully when that wire finally chafes enough to become bare it won't blow the amplifier, just a fuse in the equipment.
Do you want it your way or the right way?
Repaired HVAC duct. What did I do wrong? What did I do right? SingleGuy HVAC 12 07-07-2012 03:12 PM
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 07:25 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 10:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
