Old 03-16-2010, 02:41 PM   #1
a/c drain and sink
I recently started to remodel a bathroom sink and discovered a 3/4" drain line that was attached to the sink drain line before entering the wall after disconnecting I realized it came from the a/c -is this acceptable in the Houston area ,,When I had the house inspected in November the inspector looked in the cabinet and did not mention it,,if it is not then what is my fix ??
miguelaraujo is offline   Reply With Quote
Old 03-16-2010, 03:08 PM   #2
Pro Tech™
a/c drain and sink
As long as there is a ptrap in the A/C drain line you're good to go!
Last edited by beenthere; 04-08-2010 at 04:01 PM. Reason: Removed link to another forum
User75130 is offline   Reply With Quote
Old 03-16-2010, 03:29 PM   #3
a/c drain and sink
thanks for the reply -the a/c line comes out of the wall and turns down to meet the 2" drain line between the sink p trap and wall ,for now I connected it to a solvent reducing tee, before it was just a hose with clamps going directly to the sink drain before the p trap
Old 03-16-2010, 03:40 PM   #4
Pro Tech™
a/c drain and sink
Well if your A/C drain line is tubing, I would just coil it once, that trap will prevent sewer gas from entering your supply plenum.
Old 03-16-2010, 04:08 PM   #5
a/c drain and sink
Now I'm really lost--- what I have is 3/4" pvc s/40 drain from the a/c in the attic--so somewhere between the bathroom and the attic I have to have a p-trap ???
can the line go directly to the sink drain before the p-trap and 2" waste water line ???
Old 03-16-2010, 08:11 PM   #6
Pro Tech™
a/c drain and sink
In your case there is probably a ptrap already installed at the coil in your attic.
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
