A/C Disconnect Box - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 11:18 AM   #1
A/C disconnect box
My son recently bought a house trailer. I note the Coleman A/C has no disconnect and not even the main circuit breaker in entrance panel affects it. I also note all the other trailers in this park seem to be wired same way - no exterior disconnect box. We have no idea where it's power is coming from.
jimdwest is offline   Reply With Quote
Old 07-13-2012, 11:34 AM   #2
JJboy's Avatar
you better find this breaker quick
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-13-2012, 12:06 PM   #3
A/c
I agree. But apparently it does not go thru the main entrance panel. I don't think any repairman would work on it without a disconnect. But looks like this fairly large trailer park is wired the same. No disconnects visible on the neighbors, with same A/C. Didn't want to crawl under trailer with live power running somewhere. Flex conduit heads under trailer, but can't see where it goes.
Old 07-14-2012, 12:51 AM   #4
Someone's going to have to...
Is there a meter socket with breakers outside?
Evstarr is offline   Reply With Quote
Old 07-14-2012, 05:33 AM   #5
An old Tradesmen
Rewards Points: 7,414
Disconnect should be at meter outside. Common set up in my area.
Fused disconnect or unfused, motor is fed from breaker... Do It Right Electrical 17 03-19-2011 12:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 07:43 AM
