Old 09-03-2007, 08:23 PM   #1
Default a/c condensor working overtime
we had a problem a few weeks ago when our condenser wouldn't shut off and the house was getting hot. I figured that one out and replaced the old blower fan which was overheating and shutting down. Now it's all cooling the house down fine but when the thermostat is happy, i.e. we keep it set around 78 and when the place cools down to 78 and the thermostat clicks and shuts down the blower in the basement, the condenser keeps happily chugging along outside which makes a nice big block of ice in the coolant lines and evaporator coil. Anyone have any ideas as to why this is happening?
Dave
mallard-16 is offline   Reply With Quote
Old 09-03-2007, 10:00 PM   #2
Dave
Check to see if your contactor points are welded shut in the condenser.
Malcolm is offline   Reply With Quote
Old 09-04-2007, 05:43 PM   #3
retired
Dave
Did you undo any of the control wires in the air handler when you replaced the blower motor? If so, check to make sure you got them all connected correctly. The control wires to the condenser terminate in the air handler.
dmaceld is offline   Reply With Quote
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Hi my name is Mark Delgado with American Auto Service for Expert Village. The reason I chose this 97 Nissan Pickup was because the compressor is visible and some of the other components are just as visible. To understand the basic airconditioning system... Read More »
Today we’re replacing a thermostat will not cut off, it just continuously runs. Inside the A/C closet, which is right around the corner, there’s a light switch kind of like this one without a plate on it and you’re going to turn that... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about locating and replacing your thermostat. The first step to locating your thermostat is to locate the large tubes coming out of your radiator. On this particular car... Read More »
Learn how to remove your thermostat housing for car thermostat repair with expert automotive tips in this free online auto repair and car maintenance video clip. Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
