A/C Condenser Fan Motor Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 10:43 PM   #1
A/C condenser fan motor wiring
I am replacing the condenser fan motor and the capacitor.
The old fan motor had 3 wires (black, brown and purple). The older capacitor had 3 terminals.
My new fan motor has 5 wires (black, red, yellow, brown and brown/white). The new capacitor has 2 terminals.
I know the black is power, but I am not sure where other wires get connected. I know on the old fan the purple and the brown wires were connected to the capacitor.
When I purchased the fan motor the clerk said it is a variable speed (low & high). It is a Mars model 20465. Thanks in advance.
jcdtrader is offline   Reply With Quote
Old 06-26-2013, 11:56 PM   #2
Experienced HVAC Tech
HVAC1000's Avatar
Yellow is your common for power. Black is actually your high speed. Red is low speed . The two browns go to the two terminals on new capacitor.
HVAC1000 is offline   Reply With Quote
Old 06-27-2013, 09:19 AM   #3
Sound like this motor is for your evaporator fan not condenser.
Sent from my iPhone using DIY Forum
ryandeen is offline   Reply With Quote
Old 06-27-2013, 02:05 PM   #4
HVAC1000's Avatar
No. It's a condenser fan motor based on model number. They are multi speed to make it more universal for service techs to only carry one or two motors. Not 5 or 6
Old 06-27-2013, 03:07 PM   #5
biggles's Avatar
yellow and red are the speed not variable... either or.go with HI check the motor tag need the exact cap that was the 3 terminals
Old 06-27-2013, 03:46 PM   #6
True true
Old 06-27-2013, 09:32 PM   #7
HVAC1000's Avatar
Mars uses yellow as common. Red and black are speeds not yellow. Go with black, it's high speed. This is all on the wiring schematic on the side of the motor. You don't need the cap with three terminals. The one labeled fan will just be abandoned. You can use the three terminal dual capacitor if you want but you dont have to plus its cheaper to go with your current set up
Old 06-30-2013, 01:56 PM   #8
I hooked everything up, checked to make sure thermostat was low enough to start, checked breakers and turned it on. Nothing happened. The contacter clicked and that was it. Can you take a look at my wiring and see if I have something wrong?
A/C condenser fan motor wiring-miscellaneous-pictures-1677.jpg
Old 06-30-2013, 04:48 PM   #9
HVAC1000's Avatar
Only the brown wires should be on capacitor nothing else. It is all on the wiring diagram that came on the motor follow that as it is drawn.
Also did u realize that you were supposed to keep your dual capacitor for the compressor to start. That new two pronged capacitor is for just the fan and should be wired to nothing else.
HVAC condenser not wired properly? LynnX HVAC 9 01-24-2014 08:40 PM
Wiring new A/C condenser gbishop20012001 HVAC 10 05-12-2013 08:59 PM
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 07:57 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
