A/C Condensate Lines - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2009, 02:36 PM   #1
A/C condensate lines
Happened to notice this down in the crawlspace a few days ago and I've got a few questions for those more knowledgeable since this looks... problematic :p .
1. The secondary condensate outlet is dripping occasionally, even though I checked the primary line and it is flowing too. Is that unusual? It's probably relevant that the primary line is not perfectly sloped. There's a couple of pipes leading to the septic tank in the way and only about a two inch difference between the height of the outlet and the hole that been drilled to the outside ten feet away. So there's a section that's pretty level and then it slopes upward slightly before heading outside. Do I need to correct the slope? Regardless, should I put a trap on the primary line?
2. I assume the secondary outlet should have at least a trap on it (there's quite a bit of air blowing out it, needless to say), and probably should be run to the outside too? Obviously, the current drip is rusting the unit and putting moisture in the crawlspace.
Thanks for any advice!
bounced is offline   Reply With Quote
Old 07-05-2009, 04:02 PM   #2
An old Tradesmen
Rewards Points: 6,944
Your slope on the primary isn't enough.
Either trap or cap the secondary.
Purpose of condensate drain/neutralizer sj22 HVAC 11 02-10-2013 01:22 PM
water lines on slab toolbelt Tina Plumbing 6 05-21-2009 07:05 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 07:06 PM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 05:50 AM
