A/c Compressor Coil Resistance - HVAC - DIY Chatroom Home Improvement Forum
Old 06-04-2011, 06:33 PM   #1
a/c compressor coil resistance
what is the coil resistance of the compressor for a/c unit
durai is offline   Reply With Quote
Old 06-04-2011, 06:43 PM   #2
is it zero
Old 06-04-2011, 06:44 PM   #3
JJboy's Avatar
It's a very low resistance under 10 Ohms
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
durai (06-05-2011)
Old 06-04-2011, 07:33 PM   #4
An old Tradesmen
Rewards Points: 6,914
What coil?
Condenser coil?
Contactor coil?
The Following User Says Thank You to beenthere For This Useful Post:
durai (06-05-2011)
Old 06-05-2011, 07:18 AM   #5
it is condenser coil
Old 06-05-2011, 08:58 AM   #6
An old Tradesmen
Ok. Are you asking about electrical resistance, or are you asking about its resistance to vapor and liquid refrigerant flow?
Old 06-05-2011, 09:33 AM   #7
fabrk8r
fabrk8r's Avatar
When I read the original post I just assumed durai was asking what the resistance of the compressor's motor windings should be...which is zero.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 06-05-2011, 09:44 AM   #8
An old Tradesmen
Zero resistance on compressor motor windings would be a shorted out compressor. The compressor motor winding MUST have a resistance.
Using Electrical Resistance Wire Outdoors dj_patm Electrical 4 01-30-2011 09:12 AM
Radiant Floor Heat Mat algee Flooring 3 01-27-2011 09:02 AM
Electric thread Hi-jack brric Off Topic 19 05-28-2010 04:26 PM
mold resistance sheetrock drywall worth it stefjeano Drywall & Plaster 1 11-03-2008 06:57 AM
Cut resistance of Romex cable? Ultrarunner2017 Electrical 3 10-25-2008 02:37 PM
