A/C Compressor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 05:11 PM   #1
Electrician
Rewards Points: 760
A/C Compressor
Our compressor in our A/C has crapped the bed, hopefully it will be covered under warranty.
What would be an average time to replace an compressor in a residential A/C.
darren is offline   Reply With Quote
Old 05-29-2013, 05:20 PM   #2
Rewards Points: 6,652
When it dies, or the costs to continue maintaining it, outweigh the cost to replace. How old is the furnace, A-coil on top of the furnace and the a/c?
Old 05-29-2013, 05:30 PM   #3
Electrician
Rewards Points: 760
AC is 8 yrs old and furnace is 2 yrs old.
The compresor should be covered under warranty but I will need to pay for labour. The price he gave us for labour seemed high and would like to know what the average time to change a compressor is.
Old 05-29-2013, 05:45 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,158
3-4 hours. also depends on whether it burnt out vs seized up. if it burnt out then the system needs to be flushed with Rx11 cleaner and the job takes 2-3 more hours and filter driers need changing and new ones put on at an extra cost.
Old 05-29-2013, 06:08 PM   #5
Rewards Points: 338
mine burnt out and i'm no expert but it took awhile. it wasn't all that hard, just time consuming. i can see why the labor charge would be reasonably high.
NitroNate is offline   Reply With Quote
Old 05-29-2013, 08:01 PM   #6
Electrician
Rewards Points: 760
Thanks Yuri, with that time frame the labour seems reasonable.
Old 05-29-2013, 09:10 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
3-4 hours for old folk.
I'm putting my tools away in under 2 hours with the house cooling.
but we don't charge by the hour, we charge a flat rate and how long it takes is how long it takes.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-29-2013, 10:05 PM   #8
An old Tradesmen
Rewards Points: 6,148
Fast recovery machine and vacuum pump.
Or should I call the EPA.
The Following User Says Thank You to beenthere For This Useful Post:
HVAC1000 (05-29-2013)
Old 05-29-2013, 10:29 PM   #9
very fast. eYe tUnk wE wUz FrEaNdZ.?
Thanks.
Old 05-29-2013, 10:39 PM   #10
An old Tradesmen
Never post incriminating things. You would be very surprised who/what companies/agencies monitor forum boards.
Old 05-29-2013, 11:46 PM   #11
you guys should get some German recovery and vacuum machines. very fast.
Thanks.
Wiring a 230V air compressor jjscott Electrical 28 04-07-2013 04:09 PM
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 09:15 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 11:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
